Benefits of Waterjet
Waterjet cutting technology is one of the fastest growing major machine tool processes in the world due to its versatility and ease of operation. There are multiple advantages to adding waterjet cutting capabilities to your shop.Versatility is Our Biggest Asset
Abrasive waterjets cut material from 1/16 inch to over 10 inches thick, in high or low volume. Whether you are cutting the same thing every day, or changing materials to meet customer demands, a Flow waterjet will get your work done.
Tell Us About Your Application
Waterjet is the ultimate machine tool, no matter the application. Why? On top of ultimate versatility, there are three main benefits to waterjet cutting.
Cold Cutting Process
This means no heat or stress is imparted into your cut materials.
Satin Smooth Edge
This means you can take the part directly off of the cutting table, no secondary finishing required.
Minimal Kerf
Minimal kerf and high accuracy combined with the ability to cut virtually any material means more opportunities.
Typical industries that use waterjet technology:
- Aerospace
- Automotive
- Energy
- Oil & Gas
- Agriculture
- Architecture
- Transportation
- Artistic
Keep it Simple With Waterjet
Flow waterjets enable you to cut a variety of materials with ease. Setup and fixturing are complete in just minutes. Whatever the shape, dimensions, or material, our easy-to-use software makes the job simple. With waterjet you can expect increased productivity, fast cutting, and high quality parts.
Bring work in-house
Take control back and ensure you get the best quality parts with the ability to do any job yourself.
Cut any material
With waterjet technology, your shop has the advantage of unmatched versatility.
Simplify your process
With waterjet, get quick turnaround on jobs with extremely fast programming and machine setup.
Cut any material
Accuracy
A precise waterjet starts with the stability of the table, all the way to the control of the waterjet stream.
Flow waterjets can make parts to very tight tolerances, some systems can create parts with a tolerance as close as 0.001" (0.025 mm). For waterjet cutting, typical part tolerances range from between 0.003" and 0.005" of an inch. For materials over 1 inch thick the machines will produce parts from +/- 0.005 to 0.100 inch (0.12 to 2.5 mm).
Tolerances vary greatly by manufacturer due to differences in technology like the control, as well as machine construction.
